alpha 40 parts
alpha 40 parts
Hello all. I had a hard landing in a field today with my alpha 40 trainer. Needless to say, the front nosegear collar located above the wheel busted and i can't find it anywhere on hangar 9 site. Does anyone know where to get this part?
IA
RE: alpha 40 parts
Is this the collar that holds the nosewheel to the bracket on the firewall? If so, just go to tower hobbies, and go to collars, and find the right size according to your nose gear wire diameter.
RE: alpha 40 parts
[img]file:///C:/Users/Vicki/AppData/Local/Temp/moz-screenshot-2.png[/img][img]file:///C:/Users/Vicki/AppData/Local/Temp/moz-screenshot.png[/img]
IA
RE: alpha 40 parts
The pictures did not show up. So, its the whole nose gear assembly, the wire, the plastic piece that is mounted to the firewall to hold the gear, and the steering arm attatched to the gear? And the collar that holds the nose gear in place? Am I right? You will most likely be able to go to tower hobbies and get all those parts, or whatever parts you need. If I see a picture, I can help find the part.
