starters
AB, CANADA
RE: starters
I can't say if it will spin this particular motor. But I can tell you that 14.8V pack won't hurt your starter (intermittent duty)
Hope this helps, and I think it will actually.
-Snuts-
Can you run 2 packs in parallel, it would be better.
After re-reading your original post, the 3000mah may be light. Actually, if you run only the 3000mah pack fuse it to limit the load according to the "C" rating of the battery
-Snuts-
RE: starters
If you want better performance from your starter then always start first with voltage. Thats the magic bullit. If you are using a portable unit with 12 volt then that is hopeless especially if its a geared unit. 14.4 is better and 16.8 is about optimum. Of course the largest capacity batterys you can carry are part of the equation.
If buying new lipos frequently for your starter turns you off I would avoid lipos like the plague for starters. There is simply no easy way to keep track of and avoid deep discharges which of course destroys the battery almost every time. This is what will happen when your starter is the best performing at the field and constantly being borrowed.
John
I use two seven cell nimh packs from around 1900 mah to 5000 mah Which provides 16.8 volts in my three primary starters.
John
John
John
RE: starters
I ran my Sullivan starter on 18 volts last summer. Cheap pac from Harbor Freight that worked fine until one cell died. Be sure to add a fuse or suffer the impending melt down from a short or stalled starter. I let someone borrow my set up and learned the hard way. This year I am experimenting with a 19.2 volt 2a pac. This set up spins my Zenoah G26 like a 1/2A motor. No smoke or funny smells yet!
