Reload this Page >
Sullivan start cone...?
Old 07-16-2003, 01:47 AM
Borzak
Default Sullivan start cone...?
My Sullivan starter cone seems to be out of round now. When you put it on a spinner it bounces off pretty quick because the cone is out of round. By out of round I mean I measured it at almost a 1/4" in a full circle.
When I took the nut off holding it on I couldn't get it off - Does it screw off or is it pressed on?
Old 07-16-2003, 02:00 AM
shenion
Yes, the nut is just a locknut. I had to use some needle-nose vice grips to get mine on/off. Then grab the shaft and unscrew the hub.
If you replace it, get one of the metal hubs. They work better. Also the blue cones (neoprane?) work better.
Old 07-16-2003, 02:22 AM
Borzak
Thanks it was the end of a long day when I got around to looking at it. I've been hand flipping a while but got a new engine and it's tight so I thought I'd hit it with the starter and pow it jumps bad.
Wonder how it got so out of round tho.
Old 07-16-2003, 11:46 AM
Dsegal
> Also the blue cones (neoprane?) work better. <
Oh no. You don't want neoprene which is hard. You want the silicone rubber inserts which are soft. The color is a function of the size you need. Go to www.sullivanproducts.com/
Dave Segal
