Starter Batteries
WV
Starter Batteries
Hi
I currently own a PowerPro HD 12V Starter by Hangar 9 and the base for the battery. The question i have is which of these 2 batteries sources offered by Hangar 9 will have a longer lifetime and durability ?
1. Starter Source with 1.3Ah Gel Cell by Hangar 9
2. Starter Source with 12V NiCd by Hangar 9 (10 Cell)
I previously had the Gell Cell version and it lasted for about 6 years, I normally fly about 2 times a month. I am familiar with NICD and NIMH batteries but not sure about the Gel Cell type.
Any help would be greatly appreciated !
Thanks Scott
Thanks Scott
1 Post
RE: Starter Batteries
Hi Scott,
In a starter battery you are looking for instant current to spin the starter against the compression of the motor. To calculate the current you need the Amps and volts for each. I suspect the Gel Cel would likely outperform the NiCd but you havent supplied the info.
Life depends on storage and duty cycles, again I suspect the Gel Cel would be the go based on your 6 years of life with the previous battery. I use an old marine lead acid battery and it has been going strong for over ten years, (with regular charging).
Cheers,
Colin
Cheers,
Colin
WV
Hi
I do not know the performance qualities between these 2 batteries that is why i posted this.
Here is the link to Horizon website which shows both of the products.
http://www.horizonhobby.com/Products...?ProdID=HAN164
http://www.horizonhobby.com/Products...?ProdID=HAN163
Huck1199
I would consider using a the LIPO as you recommended but the Hangar 9 starter I own has the holes drilled specifically for these 2 packs.
Most of all i just like this setup because it is wire free and you don't have to connect it to your field box battery.
Thanks Scott
Huck1199
Thanks Scott
