Aircraft letterings
UT
Aircraft letterings
Need a few leads as to where I can find large wing and fuse NC with numbers. The Sig Waco SRE is a perfect example what I need . It's for a Stinson 108-3. Sig does not have them anymore. Really need a reply please. MM
RE: Aircraft letterings
If your airplane is covered with Monokote or Ultracoat type covering you have choices...
1 you can cut letters out of covering material using a stencil as a guide
2 you can go to a sign shop and have them cut out of vinyl
if you're covered in cloth you can paint it on...
Good luck
Good luck
TX
Mike,
I have done exactly what jetmech suggests several times. Both painted and film covering. It's cheap and easy. I used shelf paper as stencils for the painting and ultracote ironed on with low heat. I've used the windex method to apply Monokote lettering. All of these methods have worked well. Good luck.
My Feedback: (209)
Mike: call Brad at Bad Brad Graphics. He will do what ever you want cheap!
http://www.badbradgraphics.com/index.html
I had very good service from Callie Graphics for the custom stencils on my Tiger Moth. Same excellent service from Tailormade Decals for the decals and stencils for my F-22. Either will make the size you specify and the font you want. For me, unless this is a very large plane, stick on graphics are not an option. Either a stencil and paint them on or for small nomenclature, decals work well.
Try,
www.cfcgraphics.com
Does plenty of custom graphics and lettering of all sizes. Pricing can't get any better either.
I know because that's me!
Charles
www.cfcgraphics.com
Charles
