BUSA Sopwith Pup and G38
PA
I am building the 1/4 scale Balsa USA Sopwith Pup, I was planning on using a Zenoah G38. Here is my problem, with the rear exhaust the engine is to long by about a 1 1/2 inches. Has anyone used a G38 with this plane and if so how did you mount it? pictures would be great. Normally I would cut some of the firewall away at the bottom to make room, but the landing gear block is in the way.
Any ideas would be great.
PA
RE: BUSA Sopwith Pup and G38
Hi lazyace, I'm not using the bell mount,I was going to drill a hole for the shaft and mount it to the firewall. The muffler will be the problem, it's a rear exhaust.
