Thin Ca Problem
Thin Ca Problem
When I last went to work on my model, I noticed that my thin ca glue was coming out really slowly. I realized that the entire bottle of glue is gummed up and thick, rendering it useless. Does anyone know what caused this?
RE: Thin Ca Problem
Usually age will do it. CA's shelf life is limited. I keep my unopened bottles in the reefer with the beer. After they are opened then you need to take em out. Moisture is the culprit here. Also unless your doing one heck of a lot of building then don't buy the really big (like 4oz) bottles.
RE: Thin Ca Problem
CA reacts with moisture and oxygen in the air, and will solidify in time.
A properly closed container will last quite a long time.
I've taken to installing the capillary type tips on my CA bottles.
The tip is so fine that air cannot get in, yet the bottle is effectively always open and ready to dispense... ( just don't drop it! ).
I've left bottles with the tips on this way for six months and more without any problems.
RE: Thin Ca Problem
Here you go:
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL490&P=ML]CA Applicator tips - Click me![/link]
If they do clog up, just nip off a bit of the tip.
