Charging a nickel-metal hydride battery
The charger you get with these are just stupidly slow. Can I charge this with a 12 volt, car battery type charger? This is a small charger, 10" x 8" x 8".
RCU Forum Manager/Admin
My Feedback: (9)
RE: Charging a nickel-metal hydride battery
No, please don't try to charge your Ni-mh battery with a 12 volt charger. You are going to risk overcharging the battery which can destroy the battery and possibly cause a fire. If you want to speed up the charging of the battery get a charger that is designed to properly charge this batteries and where you can choose the charging level of the battery. There are many different brands out there, but here are a couple that will fit the bill:
Great Planes Triton 2
Bantan BC6-DC
Ken
Bantan BC6-DC
Ken
My Feedback: (9)
If you have the Triton JR. then you already have all you need to charge Ni-mh's. Don't hook it up to the 12 volt battery charger, but rather hook it directly to a 12 volt power supply or to a 12 volt battery. Most 12 volt battery chargers may not supply enough current for the Triton to properly charge.
Ken
Ken
I was hoping to not have to buy another 12 volt battery as I don't want to deplete my starter battery. I guess I will have to.
My Feedback: (9)
You should be able to charge from your starter battery with no issues at all. I use a lawn mower 12 volt battery for my flight box and I run multiple chargers off of it with no problems at all as well as my starter at the field. I usually recharge the 12 volt battery every month or so.
Ken
Ifound a 12V car battery on a pallet of junk batteries that wouldn't supply enough current to start a car but it is still good enough for smaller applications. I keep it around just for running my RC chargers. I throw it on a 12V charger now and then of course. It has a handle on it too so it's easy to toss in the back of the truck and take to the field if I think I'll need to charge something out there.
ORIGINAL: LokiDog
My Feedback: (-1)
ORIGINAL: pdm52956
Dude, I use the same charger all the time at the field. Hook er up to the car battery and it shouldn't give you any problems. If it becomes a concern to you, crank up the car every now and again to be sure there is juice there. If it drags at all, let the car run a little to charge it back up. You'll be fine.
ORIGINAL: LokiDog
