Ultracote Paint
Ultracote Paint
I noticed that the new range of H9 UltraPaint does not come with a white primer. So to get the colours to match, will it work better with a white base, or grey one?
Derek
Derek
My Feedback: (44)
FL
H9 Ultracote paint
I am in the process of trying to use H9 Ultracote paint for the cowl and dome of the TF Bonanza.
This has got to be the worst paint on the market. It really doesn't match the Ultracote covering (White) with the paint being more on the cream side, and after 4 days the paint still gets soft when alcohol is put on it.
I used the H9 paint because I wanted to match the covering.... here it doesn't match and doesn't seem to dry either.
JUNK!!!
Can you tell I'm frustrated!!
Bill
JUNK!!!
Bill
Ultracote Paint
Does anyone else have good things to say abt the new paint? I just tried a little, and it never seems to be hard enough, and with a 7 day wait between masking, it is way too long. 4 colours and it will take one month to paint!
Don't
Colors don't match and after two and a half weeks it's NOT FUEL PROOF !!!!!!!!!!!!!!!
Or even resistant to 15% wildcat when I tested after I noticed it came off with Windex GRRRRRRRRRRRRRRRR!
SO my next move was to use their Clear , well guess what after a week it is still soft double GRRRRRRRRRRRRRRRRRRR!
Don't they test this stuff BEFORE they sell it as Fuel resistant?
Den
Den
Ultracote Paint
Hmmm... Guess I better try the "windex test" when I get home today. I applied it to a canopy with no issues, but it hasn't been handled or exposed to fuel yet.
This is not a good sign...
Steve
Steve
Ultracote Paint
Save yourself a lot of trouble. Take a piece of covering on a piece of balsa to your local auto paint store, have them mix up a matching color and put it in a rattle can. I have never missed a color that way. I have never had one match with a covering companies paint. I won't touch them again.
My Feedback: (13)
Ultracote Paint
Well, the black I applied on the canopy is nice and dry. I put a dab of window cleaner on it; no problem. Of course, this brand of windex doesn't have any ammonia. I'll wait a couple of days more and try a dab of raw 15% fuel.
And regarding the wire gear? I chickened out and used some left-over LusterKote white primer, to be followed by some left-over LusterKote paint. No sense in tempting Fate.
The UltraPaint definitely has a strong "enamel" smell to it, where the LusterKote does not. Regular enamel is not fuel proof, so this could be the problem. Guess I'll find out when I try the canopy...
Flyboy, how much per can does your shop charge to match, mix, and make up a spray can? That's an intriguing service I didn't know anybody provided on a one-off basis. You're talking lacquer, I presume?
Steve
Steve
