How Do I Connect a Charge Switch to the Switch Harness and or TX?
Roger
not sure what you are trying to do??
Ken
I want to install a JRPA004 Charge Switch but I am uncertain of the correct connection to the JRPA001 Switch Harness and or TX, which Charge Switch connections go where?
Roger
The only difference is that the male plug where you connect the charger into is built-in the body of the JRPA004 switch.
As Ken has explained, there is no way to connect it wrong.
Regards!
I assume the JRPA004 being "JR" that the receiver can be bound through the charge jack like the JRPA001????
Please and Thank-you
Roger
[quote]ORIGINAL: LNEWQBAN
I want to install a JRPA004 Charge Switch but I am uncertain of the correct connection to the JRPA001 Switch Harness and or TX,which Charge Switchconnections go where?
Roger
Regards!
Lnewoban, thank-you so much for the information, when it comes to electric switches etc. I tend to be behind the 8 ball. The reason I asked the question is; I thought if I installed the JRPA004 alongwith the already installedJRPA001, I would be able to charge the battery and bind the TX without having to remove the wing. Can I bind the TX through the JRPA004 charge receptical?
Roger
I can tell you this:
When either one of these switches is in "OFF" position, the circuit charger-battery is closed, and the receiver is isolated.
When either one of these switches is in "ON" position, the circuit receiver-battery is closed, and the charger is isolated.
I assume the JRPA004 being ''JR'' that the receiver can be bound through the charge jack like the JRPA001????
Roger
As far as I know it doesn't matter what brand of switch you have. I never use JR brand switches and I had no problems binding my two Spektrum AR7000 Rx's to my DX7. I use EMS switches. Your radio doesn't know which brand of switch you have. If this is what you're asking.
I am sorry, ForcesR, I don't understand exactly what you are trying to do.
Good morning LNEWQBAN, thank-you for taking the time to explain switcholgy to me. As Imentioned earlier, electrical switches etc. arefar from being my strong point. It was always apain in my backside every time I needed to charge the battery or re-bind the RX using the charge jack on the JRPA001 switch (had to remove the wing to gain access to the charge jack). When I seen the JRPA004 charge switch I thought, gee I could connect that in series with the charge jack on the JRPA001 switch and never have to remove the wingwhenever I needed to charge the battery or re-bind the RX. I didn't realize that the JRPA004 charge switch wouldcompletely replace the JRPA001 switch. With your explanationI removedthe JRPA001 and installed the JRPA004 charge switch. It does what I wanted to accomplish in the first place, charge the battery and re-bind the RX without having to remove the wing; the charge/bind jack is now externally accessible. Thank-you again for taking the time to respond to my questions andlistening to my rambling, your help is very much appreciated.
Roger
