Lipo for a flight battery
I have a question you guys might be able to help me with. I have a 60 Ultrastick W/ a Evolution 100 2 stroke in it. Flys great.
I would like to use a 3S 11.1V 2200mah 20C Lipo battery for the flight (Receiver) pack. This battery is intended to run the brushless outrunner and BEC on a much smaller plane.
Batteries intended to run a flight pack are not capable of putting out as much current as this pack is.
So what... That should'nt matter.
I am running 7 standard servos W/ flaps in the plane.
The Turnigy Voltage regulator is 6.0V - 12.6V in ( 2S or 3S ) and 5.0V or 6.0V out switchable.
This should be fine...
I won't be able to monitor the lipo's condition on the out side of the regulator, but there are 3 different color LED's on the in side of the regulator to tell voltage, So I'll know aproxamitly when to charge it, or at least when to put a meter on it and check it.
The regulator says its good for 8 amps, so that should be good....
I can't think of a reason why there would be a problem with this set up,,, I just don't want to find anything out the hard way...
I really like this plane...
Teddy
Teddy
My Feedback: (14)
IN
RE: Lipo for a flight battery
I wouldn't use a Lipo for a receiver battery for one reason and that is the construction of the pack. It is not intended to be used in a vibration invironment. The construction of the cells uses very thin foil separators and the power connection is also soldered to this very thin foil. I have had the foil tear soldering a connection to it. Use Lithiom Ion or Lithiom Iron instead.
Thank you Steve,
I already have a few of these batts.. 2 are new... I'll pack it well in vibration dampining foam.
The plane these packs are intended to fly vibrates, espesially when theres a nick in the prop.
Teddy
Teddy
ORIGINAL: Steve Percifield
Not a problem to use the LiPo's in a gasser, have been doing it for over 3 years, using the same voltage reg by the sounds of it. You should be able to get a couple of hrs contunious out of that setup. I wrap my batteries in old 7mm wetsuit material, all batteries are still as got a they were new.
Cheers
I have been running lipos in my giant scale planes now for over 3 years, no problems at all, and lots of punch to feed all those servos.
Bob
Bob
Thank you for the response sensei,
I sense the lipo's your running in your giant scale planes are meant to be in an aircraft running a flight pack.
My concern is the battery i'm going to run my flight radio with was not intended to do that.
I'm gonna do it....
Cross your fingers....
Teddy
I'm gonna do it....
Teddy
