Clear Coat Fuel Proof
VA
I painted my plane with XO Rust Oil Base Enamel (Why? . . . bacause it is what I had available). I'm uncertain if this paint is Fuel resistant. Also, I had planed to use a clear coat as the final coat anyway. My problem is I don't know what clear coat to use. Will clear acrylic or clear polyurethane work . . . that is be fuel proof? This is the first time I have painted a model plane, usually I use Monocoat, etc., so I am really ignorant regarding paint.
Thanks for any suggestions.
VA
Polyurathane Clear
Thanks for the reply. I have several quarts of Min Wax Polyurethane clear (Gloss & Semi Gloss); also I have the same in spray cans. But, I have read that the Polyurathane will turn yellow with time. Have you found that to be the case?
Just a note: I tested the X0 Rust oil base enamel for its fuel proof qualities by putting some glow fuel on top of a test surface (a copper sheet) I painted white. After several days, no wrinkles in the paint. However, after wiping the fuel off, there was a faint pink stain on the white paint. So, I assume that I should use a clear top coat.
My Feedback: (7)
I think most automotive paints are fuel proof to a point. They after all are made for cars, which run on gas.
I had the same question when I painted my trainer and after a test on a section I found the paint alone was ok.
Besides, it is a trainer, and not a $400 bird that will last a long time.
Worst case scenerio if you want fuel proofing clear, there is that lusterkoat from Tower that is a clear fuelproofer.
Auto finish fuelproof?
Don't know if auto finishes are fuelproof but I just accidentally spilled some 15% on the tailgate of my pickup and it really dulled the finish. I washed it off almost immediately but it still looks flat. Should I try and use some polish on it?
CO
Re: Auto finish fuelproof?
It might have just striped the wax off the surface!
Regards
Mark
My Feedback: (18)
Re: Polyurathane Clear
I have seen the Pacta clear Polyurathane that I get from my LHS turn a little yellow. It's only noticeable on white...
VA
Unfortunately, the plane I am painting is white with black & read trim. I purchased some clear (can't recall the name of the paint . . . it is in my shop) and tried a bit on a test sheet of the white I'm using on my plane. Unfortunately, it looked slightly yellow immediately. It was fuel proof but I don't want to paint this over my white plane. Still looking for something that will work.
Has anyone used Min Wax Polyurathane clear over white? I read somewhere (in an RC mag) that Autozone has some clear spraycan paint that works (doesn't yellow and is fuel proof). Anyone familiar with this paint? Still searching for a solution! I need a solid answer soon as I just sprayed on the last coat and am sanding it smooth in preparation for the trim colors and then the clear final fuel proof coat. Help!
