Right Flyer 40T manual and CG
Reply
Old 07-19-2010, 02:33 PM
bob418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Right Flyer 40T manual and CG
All Ijust picked up a Right Flyer 40T hHere is the URLwith a picture - http://www.globalhobby.com/globalarf/rf40t.htm
What Iam looking for is the Manual for the plane - what Ireally need is the CGpoint for the plane, Ijust dropped a new engin in and want to make sure it flies right the first time!!
thanks for any help (Ihave looked and Ihave seen the CG at 3 and 4 inches from the leading edge of the wing, but Iwould like to make sure!!! thanks
Bob
bob418 is offline
Old 07-19-2010, 05:02 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Right Flyer 40T manual and CG
The links to the manuals are sometimes hard to find, but it is online
http://media.hobbypeople.net/manual/123830.pdf
carrellh is offline
Old 07-19-2010, 08:11 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used two of them for training and have yet to see a manual for one. The CG is right on the wing spar.
Gray Beard is offline
Old 07-19-2010, 09:03 PM
Lightfoot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The center of gravity is located 3-1/4” back from the leading edge of the wing, at the fuselage sides. This location is recommended for initial test flying and trimming. There is a 3/8” margin forward and a 1/4” margin aft. It is not recommended that the center of gravity be located any farther back than 3-1/2”. Balance the Right Flyer 40T Mk. II with the fuel tank empty.
Lightfoot is offline
Old 07-20-2010, 11:42 AM
bob418
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks fro the responses, but I am looking for the Right Flyer 40T(not the MKII) manual
Iwill try the wing spar which is about 4" back from the leading edge, also on the 40Twhat prop are you using, a 10x6??
Also th edumb question of the day (new guy) the WIng spare is rib or point that the leading edge of the wing goes from soild (balsa coverdto open (covered by monokote??)
Iam new to the sport and trying not crash and burn my plane on the first flight!!!
Thanks all!!!!!!
bob418 is offline
Old 07-21-2010, 02:57 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the chord of the wing? Measure from leading edge of wing to trailing edge of aileron.
From what I have read, a safe starting point is 25% back from the leading edge. If the chord is 12 inches, balancing at 4 inches should be safe.
If you have never flown RC planes, please put your zip code in the search box at http://www.modelaircraft.org/clubsearch.aspx and try to contact a local flying club for help. Most AMA chartered clubs have volunteer instructors who will teach you how to set up the model and fly it safely. You will have to join AMA and the club to get the "free" training.
carrellh is offline
