Nylon Clevises
Nylon Clevises
How much heat can a nylon control rod clevis tolerate ? I have an OS.40 FP, which gets pretty hot, and the throttle clevis is very close to the cylinder casting, almost touching it. Will it possibly melt the nylon clevis ?
RE: Nylon Clevises
Welcome to teh RCU forums, tri-squire!
Here you have a link to physiscal properties of nylon:
http://machinedesign.com/BDE/materia...demat2_29.html
Your engine should not rise the temperature beyond 320~350 next to the glow plug only.
The rest of the cylinder and body should reach lower than that temperature in normal operation.
I believe there is no problem with your set up.
However, verify that there is no intermitent metal-metal contact (between pushrod and engine body), which creates radio interference.
Regards!
Regards!
1 Post
RE: Nylon Clevises
I concur, no issues as long as there is only intermittent contact. I use a nylon clevis on my throttle linkage and have never melted the clevis.
good practice to replace that clevis once a year because heat can embrittle the clevis pin which can then snap off under vibration. Just check it every now and again and replace every season, they're cheap enough
RE: Nylon Clevises
I've been nervous about the nylon clevis too, especially close to mufflers. I have never had an issue though so I have come to the conclusions that they are just fine for the application.
As TimBle mentioned, periodic inspection and maintenance is always a good idea.
