magnum 4 stroke muffler loose
Reply
Old 07-26-2010, 06:30 PM
edmoor
edmoor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default magnum 4 stroke muffler loose
cant keep the muffler tight.....only has a single thread into the head....with a jam nut. i tried high temp. thread locker....still comes loose. cant hardly attatch a strap to the firewall as its fiberglass....and will get too hot. my option im considering is to make a strap and attach it to the engine. anyone else have a better solution for this loose muffler problem?
edmoor is offline
Old 07-26-2010, 06:57 PM
jay2000dakota
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: magnum 4 stroke muffler loose
try high temp RTV silicone on the threads or a muffler system from Macs Products
jay2000dakota is offline
Old 07-26-2010, 07:24 PM
red head
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get longer bolts !!!! ENJOY !!! RED
red head is offline
AviationNut
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try tightening the nut when the engine is hot.
AviationNut is offline
Old 07-26-2010, 07:32 PM
edmoor
edmoor's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you dont understand......there are no bolts.......just a pipe with a jam nut. im searching for red rtv ht silicone......cant find it at hobby stores......will check tomorrow at parts stores. in my opinion.....this is a bad design on this muffler setup to begin with, it can only come loose afew times.....and what few threads are in the head will gone......as the pipe is steel.....and the head is mag. or aluminum. i wont buy another engine that dont have a bolt on manifold rest cast into the head. the one pipe method is simple.....but just dont hold up.
edmoor is offline
Old 07-26-2010, 07:33 PM
oldvet70
My Feedback: (10)
oldvet70's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the pipe is only 1 thread in the head it will never stay tight. It must be threaded in much farther than that, at least a 1/4 inch or it's just going to continue to vibrate loose. The design is sound you just need to screw it in farther.
oldvet70 is offline
Old 07-26-2010, 09:50 PM
jay2000dakota
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The RTV Silicone is made By Permatex for cars. Any auto parts store should have it.
Old 07-27-2010, 12:17 AM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Third vote for the silicone gasket. Otherwise they just loosen up over a few flights.
Charlie P. is offline
Old 07-27-2010, 12:49 AM
Conrod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
3 to 4 turns of PTF tape ( white plumbers thread tape) screw the header or muffler up then tighten the lock nut. I use it at the cylinder head thread and muffler to header thread. Works on my OS, magnum and YS four strokes.
Geoff
Conrod is offline
Old 07-27-2010, 04:26 AM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Screw the jam nut back up the header to expose more threads. Then Screw the header into the engine head using the Teflon tape. Screw it in as far as it can go, then tighten the jam nut.
Steve Percifield is offline
Old 07-27-2010, 06:15 AM
Rudolph Hart
Rudolph Hart's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Short thread it's mostly to do with how you support the muffler
Rudolph Hart is offline
Old 07-27-2010, 03:02 PM
carrellh
carrellh's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Every four stroke engine I have seen has a screw in header like the Magnum and they can be a pain.
Be sure to screw the jam nuts onto the header pipe as far as possible, as in the picture. Screw the header into the engine until it stops and then back it out only enough to point where you want it. Using high temp permatex rtv or teflon thread tape is a good idea. Tighten the jam nut as tight as you can. Get the engine hot, shut it off, and tighten the jam nut again. That should help it stay tight.
Carrell
carrellh is offline
Old 07-27-2010, 05:14 PM
shiver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine sheared off in flight today[]
shiver is offline
Old 07-27-2010, 08:47 PM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Conrod
Hi
Geoff
This is the solution. It's also known as teflon tape. Works like a charm, without any fuss. No need to torque things so tight that you damage them, either.
MikeL is offline
Old 07-28-2010, 05:03 PM
daveopam
My Feedback: (9)
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also use the Teflon tape. It does not lock anything down, but instead takes the minute bit of play out of the threads and keeps the muffler from wiggling loose.
David
daveopam is offline
Old 07-28-2010, 05:59 PM
Tarasdad
Tarasdad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Never had that problem with my Saito .80. Muffler never even loosened up in flight and I made sure to check it before and after each flight. Still has the original muffler, although I did replace the header with a new one. Didn't need to, the original was still fine, just didn't look pretty any more. Once I have my Aeromaster built and my Saito in it I'll be checking it every flight again.
Tarasdad is offline
Old 07-29-2010, 06:37 AM
bps
bps's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Seems when I tighten my muffler when the motor is hot it stays.
bps is offline
Old 07-31-2010, 09:17 AM
geeter
My Feedback: (110)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
use J-B weld on the threads going into the engine. let it set overnite............works for me on my saito 100................RON
geeter is offline
