YS 120 ???
Reply
Old 07-31-2010, 04:13 AM
DennisS
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default YS 120 ???
I have an older YS 120 that always ran like a top. It sat up for a while (lubricated) and now has alomost no compression. Thoughts, ideas appreciated.
DennisS is offline
Old 07-31-2010, 12:45 PM
ChuckW
ChuckW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: YS 120 ???
Sounds like either a stuck valve or ring. I'd put my money on the stuck valve; it is common on engines that sit..
Pop the rocker cover off and see if one of them is stuck down. A little penetrating oil and pushing on them a few times will often free them up.
If that's not it, put a few drops of oil in the cylinder through the glow plug hole and turn it over a few times.
ChuckW is offline
Old 07-31-2010, 01:18 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And you are never to use petroleum products in a YS, they play havoc with the diaphragms. At this point I would do what Chuck says then order up a couple of new diaphragms and gaskets for it. When something goes wrong with a YS and it starts running bad then the diaphragm is usually the problem.
Gray Beard is offline
Old 07-31-2010, 03:45 PM
ChuckW
ChuckW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have one on the bench right now that I am rebuilding for someone. Several o-rings look like they've been eaten with some sort of chemical. Not sure what did it. some sort of cleaner maybe?
I recommended penetrating oil earlier for freeing up a stuck valve. A few drops of fuel might be a better option.
ChuckW is offline
Old 07-31-2010, 08:04 PM
MikeL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel is a much better option for a YS.  Like GB says, petroleum will eat the "soft" parts of a YS.  Chuck, it's possible that you're seeing the effects of using a petroleum-based after run oil.
MikeL is offline
Old 07-31-2010, 09:27 PM
ChuckW
ChuckW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I'm not sure what got to it but something sure did. It wouldn't run worth a crap with all those leaks. It's all sealed up now, good as new and ready to give back to the owner.
ChuckW is offline
