Spring Air Retracts
Reply
Old 08-05-2010, 06:01 PM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spring Air Retracts
I just received a set of these retracts, 700 series. They are locked in the down position and I need to know how to unlock them. This is my first set of pneumatic retracts. No instructions were provided by the manufacture.
flycatch is offline
Old 08-05-2010, 06:03 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Spring Air Retracts
Apply air to the cylinder. The gear are spring loaded into the locked down position. You can also slide the barrel against the spring and they will unlock.
TLH101 is offline
Old 08-05-2010, 06:15 PM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please explain, slide the barrel against the spring. I see the barrel but the spring eludes me.
flycatch is offline
Old 08-05-2010, 08:59 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
To retract Springairs without the air hooked up is very quick and easy. It requires a flat tip screwdriver with a blade no more than a sixteenth wide. It is inserted next to the cylinders piston and sideways next to the T bar as in the pictures. There is a molded bevel on the side of the cylinder that is the piviot for the screwdriver or the special tool.
The driver is rocked gently backward to lever the T bar and piston rod slightly out of the cylinder and it will go over center and the gear can easily be retracted aginst the spring.
John
ID:	1478771   Click image for larger version
ID:	1478772   Click image for larger version
JohnBuckner is offline
Old 08-05-2010, 09:48 PM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: flycatch
Lnewqban is offline
Old 08-05-2010, 10:11 PM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks everyone for the explanations and pictures. This hobby has such a giant pool of knowledgeable people. I used the easiest method of applying air directly to the cyclinder. Now I have more than one option. Thanks again to the people who replied to my inquiry.
flycatch is offline
Old 08-06-2010, 05:55 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Robart hand pump, that I keep a short peice of tubing on, for cycling gear that are not in plumbed.
TLH101 is offline
