four stroke help
Reply
Old 08-09-2010, 11:42 PM
grasstrimmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default four stroke help
Ok, I just picked up a used saito 82 today. This is my first four stroke. All I have ever run is 2 stroke before. It is already installed but there is not a manual with it. Anyone got any tips on the differences between the two types of motors?
grasstrimmer is offline
Old 08-09-2010, 11:54 PM
Andrewmc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: four stroke help
If you go to the horizon hobbies website the manuals are generally available for download.
If not PM me as I have one in pdf format I will be happy to forward to you - just a little big to post as an attachment.
Andrewmc is offline
Old 08-10-2010, 07:49 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's the manual
http://www.horizonhobby.com/ProdInfo...der_Manual.pdf
Just run it like your two stroke with the same fuel to see what it is like?
w8ye is offline
Old 08-10-2010, 08:02 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you run a four stroke lean, they will back fire and throw the prop
w8ye is offline
Old 08-10-2010, 12:59 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They tune just like any other engine, high speed first and then the low end. Only difference is the valves. Never run your four stroke over the stated working RPM range or you can float the valves just like in a car.
Gray Beard is offline
Old 08-10-2010, 01:23 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Saito 82 uses like a 13 X 8, 14 X 6, 14 X4W, 15 X 4W props
w8ye is offline
Old 08-11-2010, 12:20 AM
grasstrimmer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well went out and tried it this afternoon and It worked Doesnt sound like they rev as high but it ran good. Power wise how would an 82 compare to a 2stroke
Old 08-11-2010, 12:50 AM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Like a 61
w8ye is offline
Old 08-15-2010, 09:54 AM
daves
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This response is kind of late but I have almost all 4 strokes. I love them. Sound good, run good and for scale they are great. I usually use larger props with lots of 'pull'. Cuts down speed but gives a lot of pull for the RPM.
daves is offline
Old 09-09-2010, 08:22 PM
nstokes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I NEED A LITTLE INPUT PLEASE, I HAVE A HANGER9 PIPER PAWNEE WITH A SAITO 82. CAN ANYONE RECOMMEND THE BEST PROP (SIZE AND MFG). I KNOW SAITO RECOMENDS USING AN APC PROP BUT I'VE HEARD THAT MASTER AIRSCREW "K" SERIES IS MORE EFFECTIVE. WHAT SHOULD THE RPM RANGE BE FOR THE PROP ALSO?
nstokes is offline
Old 09-09-2010, 09:10 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Master Airscrew 14 X 6 and about 9200 rpm
w8ye is offline
Old 09-09-2010, 10:11 PM
nstokes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS, I'LL TRY THAT ONE NEXT TIME OUT.
nstokes is offline
