nose up test
Reply
Old 08-16-2010, 08:14 PM
joco1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default nose up test
When you do the nose up test,and it runs fine when you raise the nose but it dies when you point the nose down ,what does that mean?
joco1 is offline
Old 08-16-2010, 08:46 PM
d_bodary
My Feedback: (85)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: nose up test
A: You flooded it
B: You uncovered the clunk
d_bodary is offline
Old 08-16-2010, 09:02 PM
joco1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks!
joco1 is offline
Old 08-17-2010, 07:09 PM
joco1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane im flying is a omp profile with a 55ax installed on it ,tonight when i was flying i did a few loops and a few rolls and then it just didnt sound right so i landed and could see alot of bubbles in my fuel line! What causes this and where do i need to start to fix it?
joco1 is offline
Old 08-17-2010, 07:21 PM
huck1199
huck1199's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel is foaming or air leak in fuel line.
huck1199 is offline
Old 08-18-2010, 08:05 AM
rlipsett
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
fuel line air leak might also be inside the tank. Best solution is to replumb the tank with new lines inside and out it is only about a dollars worth of tubing. make sure you have foam under the tank but not compressed hard and rigid
rlipsett is offline
Old 08-18-2010, 09:55 AM
SeamusG
SeamusG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey glow experts out there. What is the goal of doing a full throttle nose up test at the starting bench? What are you looking (or hearing) for? How long do ya hold it up?
SeamusG is offline
Old 08-18-2010, 10:12 AM
TFF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are listening for the engine leaning out. With most standard fuel set ups, when you hold the nose up the engine will lean out. What you want is the max safe lean condition with the nose up and the engine running good in straight and level position. So if your plane is known to lean out a bunch, you really want to set the mixture with the nose up.
TFF is offline
Old 08-18-2010, 10:14 AM
Chad Veich
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: SeamusG
The goal is to determine if the engine is too lean. When you hold the nose up the engine will lean out slightly due to the fact that the engine is having to work harder to draw fuel due to gravity. If the needle setting is too lean the engine will lose RPM (sag) or quit completely when the nose is held up. Ideally the needle should be set just slightly rich when the airplane is level so that it gains a few RPM when held vertical. You should only have to hold it vertical (at full throttle) for a 5-10 seconds to figure out all you need to know. That's my .02 cents anyway.
Chad Veich is offline
Old 08-18-2010, 10:37 AM
SeamusG
SeamusG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gotcha - a friend (2nd plane newbie) at the field held his 4Star40 w/ OS 55 AX up at full throttle (13K rpm). He held it up for 5 - 10 seconds. No change in rpm. Following the posts I'm going to recommend that he richen the high speed needle a click or 2 then retest.
Thx for the input.
SeamusG is offline
Old 08-18-2010, 11:36 AM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, when the airplane's prop 'unloads' while flying the mixture will lean out a little. You definitely want the mixture slightly rich in level attitude.
ARUP is offline
