Satio 180 Question
Reply
Old 08-17-2010, 05:55 PM
BarksKT
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Satio 180 Question
I have a good running Satio 180. I took out the needle valve to remove the cowling and since I reinstalled the needle valve I can not get the engine rich enough. It runs VERY lean. I have cleaned the carb and checked the lines. There is plenty of fuel reaching the carb.I have not touched the low speed needle valve so to me that should not be a problem. I am out of ideas and need some help.
BarksKT is offline
Old 08-17-2010, 07:30 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Satio 180 Question
If you go into the glow engine forum you can ask a Saito factory tech and probably get a more informed answer or read some posts from someone that has had the same problem to see what there cure was.
Gray Beard is offline
