Ordered new plane.... How to change this?
Reply
Old 08-17-2010, 07:53 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ordered new plane.... How to change this?
I just ordered a new plane and will recieve it next week. I like the looks of the plane but hate the big "G-KEMY" all over it.
Is there a way to remove that or paint/paper over it? I want to add my business Logo to it.
CGCINC is offline
Old 08-17-2010, 08:41 PM
ChuckW
ChuckW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ordered new plane.... How to change this?
It is likely just an adhesive decal and you can probably peel it off if you are careful then replace it with any good vinyl decal for your choice. If you are really lucky, the decals won't even be applied, they might just be on a sheet in the box.
Is this your first airplane?
ChuckW is offline
Old 08-17-2010, 08:50 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: ChuckW
Yes, this is my first plane. I'm hoping not to remove the lettering by nose diving into the ground....
I'm pretty sure they are on the kit already...maybe a hair dryer will do the trick.
Thanks for the help!
CGCINC is offline
Old 08-17-2010, 09:59 PM
Bill Diedrich
Bill Diedrich's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not to rain on your new plane but the receiver in this plane is for park flyer types of
aircraft only and will not have the range required when you decide to move up to the
next stage of airplane, especially glow powered airplanes as it has a very short reception
range, so beware when & if you intend to use it in a larger, faster & farther flying aircraft.
Good luck on flying your new toy.
Bill Diedrich is offline
Old 08-17-2010, 10:20 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Bill Diedrich
range, so beware whenm & if you intend to use it in a larger, faster & farther flying aircraft.
Yeah, this one is for learning and flying at my house.... it was $139 so I figured it might make a good gift for my nephew if it survives me.
I do plan on moving up but I will be buying Much better equipment.
CGCINC is offline
Old 08-18-2010, 03:30 AM
Steve Percifield
My Feedback: (14)
Steve Percifield's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please seek flight instruction.
Steve Percifield is offline
Old 08-18-2010, 05:47 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Steve Percifield
Ditto!
MinnFlyer is offline
Old 08-18-2010, 06:55 AM
mclina
mclina's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know that I would try a hair dryer to remove the decal from the foam. You could end up melting the foam. You could also end up taking some foam with it if you just try to peel it off, and any kind of solvent that will loosen the glue will probably also melt the foam.
Covering it may be a better way to go, but you'll be adding some weight, and all on one end of a wing.
Fly it first, and then worry about what's written on it.
Good luck
mclina is offline
Old 08-18-2010, 07:51 PM
mc15601
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: CGCINC
Just rename your company "G-Kemy"...problem solved.
mc15601 is offline
