Spend my money.... Transmitter??
Once I figure out the basics of flying I'm going to jump to a gas trainer.
As far now, I'm planing ahead a little and just trying to schuffle through the many, many transmitters out there and figure out what I need.
Need your Input:
I want to buy a transmitter that will work with simulator software, be able to fly multiple planes,have enough channels to grow with me and do anything else that I do not realize I need yet.
What type/brand would you buy and why? (up to $350or so)
When I decided to upgrade, I choose a DX6i 6 channel. Main reason I suppose is because I could afford it to begin with and the owner of my LHS recommended it as an entry level 2.4 radio that would do what I needed for quite a while. I was, and still am, happy with that radio.
I've recently gotten a JR 9503. The reason I made that move is because I recently put my first 50cc plane in the air and although the DX6i is capable of working just fine with it, I wanted something that was more capable and would serve me better in giant scale. I still have the DX6i, don't plan on getting rid of it and I have my other planes still bound to it for the time being.
Now, instead of looking at the 6 channel, you might be served better by looking at the DX7. It will take you farther in the hobby although 6 channels can get most jobs done with a little assistance from things like Y harnesses. You'll hear that a Y harness is just another failure point, and by all means it is since it is electrical, but I have a few in my planes and haven't had any issues with them.
The other part of your question about the tx involves a ton of personal preference based on brands. Me, I like the Spektrum and/or JR radios. A number of people I know have gone to the Aurora 9 and I know others that prefer.........well what ever they are flying with. In other words everyone has their own opinion on what tx is better and why. Best advise I could give would be to take a look at what is available in the number of channels you can afford, then go to the LHS or club that you're a member of (or thinking about joining) and talk with them. Put a couple different radios in your hands and see what just feels right to you. Each will have it's own "feel" and if it doesn't feel right, you won't like it.
Oh, did I mention that if you're starting out, you might want to consider looking into a club? You'll find instructors that will be happy to help you out, both with learning to fly but also with advise as to what type of equipment you might look at. It also helps to hook up with an instructor before you purchase items that you'll use to learn with. If you choose to use that particular instructor to learn how to fly, he may have good advise that you can use to make better choices when making those purchases.
Other than that, I wouldn't want to try to steer you towards one over the other simply because what I find works best in my hands may not in yours. Get a grip on a couple of different radios and go from there.
Most importantly, have fun!
I am planning on going to a big RC store this weekend so I will do a little hands on research.
Minnflyer...I actually was looking at the Futaba 7c with FASST (Futaba Advanced Spread Spectrum Technology)
Sounded like a better way to stop any signal loss.
My main thing is Channels? Will 6 work or will I need7-8 in the future?
As for the Spektrum-JR/Futaba debate, I fly both and don't have any problems with either one.
Go to the toy shop, hold the radios in your hands, play around with the programming, and find out what works and feels best for you.
I second the Futaba's. I have owned the other brand and I went back to Futaba. They are reliable, easy to program, simple to bind and I like the receivers much better. That's not to say JR/Spektrum is bad; they are good radios, just not my preference. You may also want to take a look at some of the offerings from Airtronics. There are a few at the field and I am impressed with the radio they provide for the money.
Its not only the number of channels but the depth of programming, ball bearing gimbals etc that you get with the higher end radios.
6 channels will get you by for a very long time. Even most .60 size warbirds can be flown on 6 channels. It is when you get into the large scale, more complex airplanes that you need more. My main radio has 8 channels but they go unused in most of my airplanes.
The standrd plane needs 4 channels - Ailerons, Elevator, Throttle, and Rudder. Then you start adding things like flaps, retracts, lights, bomb drops, etc... All of theses require a seperate channel. If you decide to get into 3D or other styles or aerobatic planes you will need the extra channels for setting up the mixes in the computer radio. To do this you need each aileron will need to be plugged into its own channel, you may need a kill switch for gas engine ignition. I could go on.
Ultimately get as many channels as you can afford. Go talk to the guys at your local field and see what they are using. There are benefits to using what everyone else has because they can help you if you get stumped programming something.
I have a 7C that I bought last year and I love it. It is easy to program and the switches are laid out very well. As far as channels go the more the better. I would recommend you buy as many as you can afford. If you want to get into scale warbirds or other types of planes that do more than fly you will want the additional channels.
I'm sure the 7c will work for years to come!
One little problem I have is that my simulator software is on its way and I got the software only with no controller.
7C is a mid level radio, on par with a DX7
The 8 and 10 series radios are a step up on par with the 9303/9503 from JR and the new Spektrum 8 channel.
Then you get into the expensive +600 dollar stuff like the 699 JR 11x and the 12 and 14's from Futaba.
As for reported problems, there's a lot more people flying DSM2 (Spektrum/JR stuff) hence you get more reported issues. However remember the following things.
1. You should use proper equipment selection and installation and operation practices no matter what radio you install.
2. Any electronic equipment can fail though on the whole, most of our mainstream equipment is remarkably reliable.
Pick up a used 72mhz radio for it. They're dirt cheap. If you can't find someone locally to just give you one, you could probably buy one here or at RCG for $30 or less, shipped. All you need for a sim is a 4-channel, mainline brand that's compatible with whatever software you purchased. Alternatively, they sell USB transmitter-like boxes that are just for sims.
Futaba 6EX or 7C
Much less hassle binding or placing receivers.
Do a search for radio problems and you'll find there are very few Futaba compared to Jr or Spektrum.
Futaba 6EX or 7C
9 channels
30 model memory
Assignable channels
Back lit touch screen....................
Aw heck, just look here: http://shop.tomsrc.com/product_info....oducts_id=2639
and a good 7 channel , because if one is down on the charge , you got a fully charged backup on the other one
Sure, why not? I've got an Airtronics RD6000 that I'll never use again. I've got the manual and charger for it, too. PM if it'll work with your sim and you'd like it.
I don't see it on there unless its called something else. That sux!!
All JR MC/MX (no adaptor required) - ** MC-series requires "DSC Interface" Accessory **
• Spektrum DX6 / DX6i / DX7 / DSX9 (no adaptor required) - ** NOT new DX7 Special Edition "SE" version **
• Spektrum DX5e older-style with SIDE training port ("DX5e adaptor" required)
• Spektrum DX5e new-style with REAR training port (no adaptor required)
• All Futaba ("Futaba/Hitec round" or "Futaba square" adaptor required)
• Futaba FX-18 with 2.5mm stereo training port ("Futaba FX-18" adaptor required)
• Hitec Aurora (no adaptor required)
• All Hitec except "Aurora" ("Futaba/Hitec adaptor" required - "Aurora" requires no adaptor)
• All Multiplex ("Multiplex" adaptor required)
• All Sanwa RD and RDS series ("Sanwa adaptor" required)
• E-sky ETB41 2.4 ghz (no adaptor required)
• Other E-sky ("Mini-DIN adaptor" required)
• Co-Pilot ("Mini-DIN adaptor" required)
• Blade CX, CX-2, CX-3, CP, CP+, CP Pro, CP Pro 2 and Blade SR (no adaptor required)
• Parkzone Transmitters with training jack ("DX5e adaptor" required)
• Art-tech 100B (no adaptor required)
• Art-tech 100C ("Art-tech 100C adaptor" required)
• Walkera 2401, 2601 (Using "MINI-DIN adaptor" supplied with transmitter)
• Walkera 2402, 2602("Walkera 2801 adaptor" required)
• Walkera 2801 ("Walkera 2801 adaptor" required)
For $350, the Hitec Aurora 9 is the hands down winner.
9 channels
30 model memory
Assignable channels
And 9 channels...
