parkzone wild cat
Reply
Old 08-21-2010, 09:51 AM
cloudwalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default parkzone wild cat
Hi Guys, I wonder if you can help please?. Ive just bought a parkzone wildcat and cant get it to balance. I have a 2200 lipo installed , the instruction call for a 1300 up to a 2200. When I try to balance the model after adding a small amount of weight to the tail, I can get it to stay in the horizontal for a second or two before it will drop either nose down or tail down. I cant figure out if its tail heavy or nose heavy. If I remove the weight from the tail it will go hard nose down, but I cant fine tune the balance. I have tried having the model upright and also inverted with the same result. Any help will be greatly appreiated. Thanks in advance. Bill.
cloudwalker is offline
Old 08-21-2010, 10:36 AM
Villa
Villa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: parkzone wild cat
Your excellent description causes me to believe that your plane is perfectly balanced. Fly it.
Villa is offline
Old 08-21-2010, 01:29 PM
JohnBuckner
JohnBuckner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the model is the F4F Wildcat then that would explain the difficulty in balancing. The Wildcat was a true mid wing aircraft and this make balancing much more of a challange simply because the midwing does not have added static stability like a low wing would balancing inverted or a high wing being balanced upright.
Many of the midwing sport aerobatic types also a bit more persnickety on the balance stand. I agree with Villa it sounds like you close enough with the lead installed.
John
JohnBuckner is offline
Old 08-21-2010, 02:00 PM
cloudwalker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks John and Villa Bill.
