Calibrate throttle-stick Futaba 14MZ and FX40
Info how to calibrate throttle-stick Futaba 14MZ and FX40
Futaba 14MZ has throttle stick stops. If you remove this you must calibrate the throttle stick. It took me 1 day to find all information and software to be able to calibrate the throttle-stick on my Futaba 14MZ.
I putt up all info you need on my homage saw you do not need to spend saw much time to find every thing you need if you like to do the same thing.
You are able to update more:
All info you need you will find here: [link]http://www.rcflygskola.se/Throttle-stick%20Calibration%20Futaba%2014MZ%20and%20FX40.h tm"]http://www.rcflygskola.se/Throttle-stick%20Calibration%20Futaba%2014MZ%20and%20FX40.h tm[/link]
I hope my instructions will be helpful for you.
/Kristian
/Kristian
