Reload this Page >
New plane is here!! Question on engine cover?
Reply
Old 08-27-2010, 05:28 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New plane is here!! Question on engine cover?
I just bought a Cessna large scale and in the instructions it says to permanently glue the engine cowl on to the fuselage.
I'm thinking about when I need to work on the motor or adjust the front steering on the landing gear which is inside this cover.... How would I get the cover off?
Is there something else I could do to make it accessable?
CGCINC is offline
Old 08-27-2010, 06:07 PM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New plane is here!! Question on engine cover?
How large is "Large Scale"?
Which plane is it?
MinnFlyer is offline
Old 08-27-2010, 10:28 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: MinnFlyer
Which plane is it?
This plane.. http://www.parkflyers.com/Cessna_Lar...ne_p/4303l.htm
CGCINC is offline
Old 08-27-2010, 10:33 PM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's more like medium sized, but big for a park flyer definitely.
Most nitro models with cowls attach them with screws to the fuselage because it's assumed that you'll have to get to your engine at least once. Are you able to do that?
jester_s1 is offline
Old 08-27-2010, 11:00 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jester_s1
No, its a slip fit type thing. I suppose if everything goes perfect I will not need back in there but that probably won't happen.
Clear tape would work but it looks bad so I guess I'll just glue it.
CGCINC is offline
Old 08-27-2010, 11:10 PM
ChuckW
ChuckW's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The names these Chinese companies give their airplanes crack me up sometimes. So does some of the stuff they put in their instructions.
I absolutely would not glue the cowl. You will likely need to remove it at some point. Use small screws (if there is something in the fuselage for them to bite into), strong tape or magnets that will allow you to remove the cowl.
ChuckW is offline
Old 08-27-2010, 11:23 PM
davidgeorge212
davidgeorge212's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow, I guess ive never seen a cessna do torque rolls. I guess there is a first time for everything!
davidgeorge212 is offline
Old 08-27-2010, 11:27 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: davidgeorge212
LOL... This is actually a pretty nice kit compared to my other plane I bought. I'm a long way from torque rolls!!
CGCINC is offline
Old 08-28-2010, 01:14 PM
Gray Beard
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would use silicone to attach it. On some of my planes with LG skirts I just run a bead and stick them on. It holds very well and can be removed with a bit of effort.
Gray Beard is offline
Old 08-28-2010, 01:32 PM
mikegordon10
mikegordon10's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd like to second GB idea of using silicone. Sounds like a good idea, even better than screws, tape or gawd forbid glue! There is absolutely no doubt that you'll need to get back in there sooner or later. prolly sooner!
Park Flyer's must be listening to a different drummer if this is Large Scale! To me Large Scale starts at about 80" wingspan and goes up, way up, from there.
mikegordon10 is offline
Old 08-28-2010, 01:48 PM
dbacque
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You should never build a plane such that it can't be serviced. The cowl should absolutely be removable.
If it doesn't slip over the nose of the fuse and there's nothing to screw it to, glue some hardwood or ply blocks to the firewall. Set the blocks back from the edge by the thickness of the cowl. Tape the cowl in place and drill through the cowl and block to give accurate screw pilot holes. Then enlarge the holes in the cowl to the screw clearance size (screw drops into hole but stops at head).
What's even better than screwing into just the wood is to drill through both cowl and block with the clearance size bit. Then drill the blocks out larger so you can glue in pieces of yellow nyrod. The screws going into the nyrod will not rattle loose and the holes won't wear out. I also like to use a nylon washer on the screw to protect the cowl.
Dave
dbacque is offline
Old 08-28-2010, 02:51 PM
Hewey19
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think I would use some Goop to attach it.  Whatever kind you can find at the store, Amazing, plumbers, etc.  It is like silicone but holds better but can peeled off it needs to be removed.
Hewey19 is offline
Old 08-28-2010, 05:26 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has a wide flange where it slides on so I bought some super strong magnets and gonna try that for now. The battery panel is held on this way and it Really holds tight.
CGCINC is offline
Old 08-29-2010, 11:21 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Hope you don't try that plane yourself It's not that good as a trainer...Too much scale look! join a club and get good instructor.
A good trainer plane looks like this.
Plane is a Kyosho "Calmato", Spans 160cm, lightened 500g and modified to taildrager. Runs a MVVS .28 engine swinging a modified 11x4 APC prop.
ID:	1491975   Click image for larger version
jaka is offline
Old 08-29-2010, 12:28 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jaka
Hi!
I've already got another plane that is basically like it. Of course this one is better quality.These are my Trainers!!
CGCINC is offline
Old 08-29-2010, 01:10 PM
scooterinvegas
scooterinvegas's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone else notice that something came off the plane at 22 sec into the video?? Must not been to important, it kept flying
scooterinvegas is offline
Old 08-29-2010, 07:54 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: scooterinvegas
Apparantly they need a better battery hatch fastening system. You can see it missing in later belly shots. In the landing (last few seconds) it is hanging open. So, we can also conclude that video is a composite of multiple flights.
Charlie P. is offline
Old 08-30-2010, 12:16 AM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has small magnets holding it. For the hatch I'm using Super magnets so there's no way it will come off....I might add some to both belly covers too.
CGCINC is offline
Old 08-30-2010, 05:11 PM
basman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The new high wing Edge ........................3d
basman is offline
Old 08-30-2010, 05:24 PM
AB Bob
My Feedback: (20)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CGCINC,
Good luck with your new plane. I hope you will enjoy the hobby as most of us on here. I started with a 63" glow trainer, and now I have planes with 9-10 foot wingspans.
They fly so much better, but require a dedicated RC field to fly them. I've met tons of new friends and many of them have planes as big if not bigger. Its an addiction for me. Hope you catch it too.
AB Bob is offline
Old 08-30-2010, 05:58 PM
Tarasdad
Tarasdad's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Personally speaking, if there were enough overlap of cowl and fuselage I'd inset some hardwood blocks into the foam with epoxy then use screws to attach the cowl. Might even use blind nuts on the back side of the wood if there's enough clearance behind the block. Old-fashioned it may be, but that's me to a T!
Tarasdad is offline
Old 08-30-2010, 08:43 PM
CGCINC
CGCINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the magnets and it pulls the cowl in tight from an inch or so. I used 5 magnets but I think it was a little overkill.
CGCINC is offline
