Engine / fuel problem
Reply
Old 08-30-2010, 06:58 PM
ES CONTROL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Engine / fuel problem
I have 85 flights on a UCD with 2nd. engine and I am having problems.
The 2 stroke (mounted inverted) will start , run for 5 Min. than lean out like a vent tube is clogged. But if I blow air through , everything is free.
So I try again this time less than 5 Min. I start to open needle valve and continue opening 3 turns till engine dies. (lean)
I burnt out 3 glow plugs so far. I am going to pull tank and replace fuel lines next. Is their any else ?
P. S. A smoke system ( installed 5 flights ago) may be the cause .
ES CONTROL is offline
Old 08-30-2010, 07:27 PM
DMcQuinn
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Engine / fuel problem
It certainly sounds like fuel starvation. Try this. Fill the tank. disconnect the line at the carburetor. let it hang a few inches below the bottom of the tank (put an extension on the line if you have to) to start a siphon into a clean container. The entire tank should be siphoned out at a fairly brisk pace (2 or 3 ounces per minute). If the rate of flow slows down or stops then you know you have a tank / plumbing problem.
DMcQuinn is offline
Old 08-30-2010, 07:33 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to re-do your tank
Also the UCD's are notorious for the tank being too high
w8ye is offline
Old 08-30-2010, 07:42 PM
ES CONTROL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good ole Missouri !!   End of Sept. I get 2 weeks of vacation on dads farm in north east Mo.
Old 08-30-2010, 07:49 PM
ES CONTROL
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks .  I found 2 cracks and 1 melted spot so far.
