Delta Wing C of G calculator
Reply
Old 08-31-2010, 01:16 AM
maxjanet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Delta Wing C of G calculator
Hi,
I have just bought a second hand delta model, and I have changed the old .40 size engine to a new OS 46 AX engine which is 83g heavier. I would like to find a C of G calculator which I can just enter the models dimensions into and get ball park C of G for this model. The models span is 1260mm: length is 750mm: and tip span is 230mm. Can anyone please help me with an easy to use C of G calculator program? Thanks!
maxjanet is offline
Old 08-31-2010, 05:58 AM
guille2006
guille2006's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Delta Wing C of G calculator
PM me your e-mail... I've a nice one that might help.
In any case, if the CG is going forward, don't worry too much, you're just gaining stability.
Cheers
Guille
guille2006 is offline
Old 08-31-2010, 08:10 AM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As Guille has stated, the stability will improve.
http://www.geistware.com/rcmodeling/cg_calc.htm#cg
Check this post before you select the stability margin:
http://www.rcuniverse.com/forum/fb.asp?m=9265664
Lnewqban is offline
