RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Questions and Answers (http://www.rcuniverse.com/forum/questions-answers-154/)
-   -   .049 Cox engine RC build (http://www.rcuniverse.com/forum/questions-answers-154/3561619-049-cox-engine-rc-build.html)
flyingjon 11-17-2005 12:15 PM
Hello Sky Flying Lovers,
I am building a .049 size Cox engine pusher sail plane.
I intend to use the 7.6 grams S3108 Futaba micro servo using the 7 Ch R127DF receiver and the futaba nr4qb 4.8dc volts Nicad pack .
I would like to know if this set up will work to give a good short RC flight ?
Will the micro servos provide enough torque or will the 4.8 volt cell pack be good enough and work without causing damage to the microservos.
Thanks for all the help.
Stay tuned in for the flight report!!Cheers!!
sbd-5 11-17-2005 02:37 PM
RE: .049 Cox engine RC build
servos torque depends on the size area and amount of deflection of the control surface.you did not specify what size the model is.all servos can run on 4.8 volts without damage some can also use 6 volts.you did not indicate what the mah rating of the pack is.i built a champion fokker eindecker with a cox dragonfly engibne,had throttle and muffler used 3 tower s-10 mini servos and 4 ch mini reciever.with williams bros wheels and a small 100 mah pack weight is 17 oz.flys about 5 minutes full throtle idle is about 4000 rpm but slow enough to landunder power
MinnFlyer 11-17-2005 03:38 PM
If your sailplane will fly with an .049 for power, those servos should work just fine.
flyingjon 11-18-2005 07:25 AM
1 Attachment(s)
Ok Posted here is a picture of my incomplete Black widow Cox pusher sail plane or is it a glider.Its wing span is 4 feet with a wing chord of 6 inches.Its an all out Foamie.
The set up mentioned by me uses a standard normal reciver with a 600mAh 4.8 volts. I have not weighed the over all weight.
Else, I intend to use smaller Nimh 180mAh smaller than AAA cells,cut down on the weight ,But I am worried about the servo torque.I think the elevator area is about 20sq inches and the rudder is roughly around 10 Sq in
I have to yet add the micro servos!
flyingjon 11-18-2005 07:31 AM
1 Attachment(s)
I think this should give a rough idea of the size and area of the tail plane. I will try to keep the elevator and rudder deflections as little as possible.
MinnFlyer 11-18-2005 09:25 AM
Cute plane!
I think a standard battery should work ok
sbd-5 11-18-2005 12:07 PM
just remember to balance this with a full tank of fuel as the tank is behind the cg.that way you will not be tail heavy at launch.
flyingjon 12-04-2005 03:58 PM
1 Attachment(s)
Thanks to all the expert replies !! The pusher flew just great
flyingjon 12-04-2005 04:05 PM
1 Attachment(s)
The joys of building and flying foamies!!!The next project is a glider with a Mills engine up front.
Enjoy
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
