Can u bend Depron foam?
Can u bend Depron foam into smooth curves? And also, what thicknesses does depron come in?
RE: Can u bend Depron foam?
depron appears to only come in 2 thicknesses but i could be wrong,these are 3mm and 6 mm,it has a grain just like wood which you can ascertain by bending it just like you can with wood,it won't take much of a curve without heat but will stay curved if you use heat on it
