RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   i need a little more power (https://www.rcuniverse.com/forum/questions-answers-154/3643495-i-need-little-more-power.html)
marlinmodel60 12-11-2005 09:20 PM
I have a superstar ep i would like to hop it up any ideas? I dont want to use a brushless set up for various reasons.PLEASE HELP!!!!!!
JohnW 12-12-2005 04:05 PM
RE: i need a little more power
The best hopup, most bang for the buck, would be exactly what you indicated don't want. I.E. a brushless setup. Until an efficient motor is mounted on the firewall, everything else is a waste of money IMO. I know they don't exactly give away brushless motors and controllers, but once you bite the bullet and get it, you'll wonder why you even messed around with the brushed motors in the first place. Cheers.
kdheath 12-12-2005 05:41 PM
Agreed that brushless is the state of the art, but at least try some different props to get you by until you can upgrade.
Campy 12-12-2005 11:09 PM
For a little more "oomph" try the following:
Get a battery with one more cell than you presently have. The majority of brushed motors and ESC can handle one more cell safely.
Try different diameter and pitch props.
Try different gear ratios.
Before going and spending all that money, D/L MotoCalc. You can use it free for 30 days. Input the data from your plane into motocalc and then play "what if" to see what will be the best way to do things.
