Stripping paint
Does anyone know of a good method for stripping / removing the paint from a fiberglass cowl and wheel pants and aluminum gear in order to repaint them?
Thanks, Jim |
Stripping paint
Jim
Loctite used to make a paint remover that worked great. I just stripped plane using a paint remover I got at Home Depot. Messy but it worked fine. The plane was glassed using epoxy and it didn't hurt the underfinish John Kruger |
paint remover
hello,
on fiberglas parts be careful with paint strippers as some will eat the resin especially polyester resin.safest paint remover i have found that works on plastic but may take awhile is plain old brake fluid.soak the parts covered in fluid for a few days and scrub with a tooth brush.or cover with wet towels soaked in brake fluid wrapped with plastic to prevent a mess. |
