RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   covering over foam (https://www.rcuniverse.com/forum/questions-answers-154/4811307-covering-over-foam.html)
markus-RCU 09-30-2006 12:27 PM
covering over foam
I am trying to cover a foam wing with monocoat or econocoat on a combat wing. The econocoat says that it sticks to foam but I am not having any luck with it. Do yoou just have to wrap it and then use low temp or just use some 3m spray to make it stick.
super tigre 09-30-2006 12:52 PM
RE: covering over foam
Econocote does work well,are you applying enough heat? I would test in a small area or on a piece of scrap to get the heat set. and did you remove the backing off of the ecnocote.hope this helps.
Steve
AMA#511248
