Taking old fabric
Hello all.. I have a old sig 1\2 scale cup that has been covered in fabrics. The plane is in good shape but it needs to be recover. I have hard that it is hard to take fabrics off. Can I get the old covering off and how would I do it
Thanks Paul |
RE: Taking old fabric
I did not do that right. It is a 1\4 scale.
depends if it is an iron on covering or a doped on covering.If it was ironed on then an iron set at the temp needed to re activate the adhesive will allow you to remove it.
