prop question
what prop to use on my thunder tiger pro 120 2 stroke. thanks in advance. (funtana 100x
RE: prop question
15x6 works great on my saito 120 in a 10 LB Pitts.
RE: prop question
Hi!
It depends on what model you have in mind for it! pattern plane or scale...??? A Saito 1.20 four-stroke works best with a with either a 15x8 or a 16x6 APC ...not a 15x6! Aim for rews under 10.000 with a 1.20 fourstroke! Regards! Jan K |
RE: prop question
LANNYBOB sez it's a 2 stroke not 4 like the answers alledge.
FYI I have a GMS 120 2 stroke on a Harrier .90 3-d and use a 15-4. If you don't have a 3-d plane I'd go with a 15-8, 15-10 or a 16-6 if you have the ground clearance. |
