My second glow plane?
Hey, I'm still flying, haven't killed anyone yet, although I did scare the heck out of my flying buddy last week-end. I'm about ready for my post-trainer airplane. I would like to buy a plane that's a good slow flyer. I'm interested in the Thunder Tiger Slow Tiger, the Mustang look a-like. Is that a good choice, any suggestions?
2nd airplane
Don't know about the Thunder Tiger plane, but I would recommend the Goldberg Tiger II, or the Sig 4-star 40. There are also .60 size versions of both those planes. Both build easy, fly great, and land slow.
Good Luck! |
If you want a good slow flier, then get either the GP Slowpoke or the SIG Hog. Both are great slow fliers!
great planes easy sport, hop bipe, tiger 60, there are lots of good second planes. Good luck, Loren
kennydee, the Lazy Tiger P-51 is a great flying plane........but it's more of a "2nd second plane" (if that makes any sense)......It does flies extremely slow, but can easily get out of control in the hands of a newbie. I got one about a year after I started flying....and it took me about 10 flights to really start getting comfortable with it. It's a little difficult to take off and land on a paved runway....it ground loops like crazy. I unfortunately lost mine to a mid-air.
Mike |
Consider a "Stick" come in several sizes and makers. If you want a low wing with tail gear then go with the 4 Star. Pete
He wanted a good slow flyer. I guess it depends what each of us call slow! :D
Roger That :D
Thanks for the input. Funny, when I asked experienced RC pilots I kept getting suggestions for planes that landed slow. I am actually looking for a plane that will fly and manuver at slow speeds as well. I considered the Slow Poke and a couple of others but ended up buying the Lazy Tiger. Glowplug, I bought this plane before I read your note, I'll use my co-pilot to ease into this plane. I enjoy flying low and slow and others have told me the Lazy Tiger would do that well. Any other info on setting up the Lazy Tiger would be appreciated. Thanks Again
kennydee...keep the aileron and elevator throws small (especially the ailerons) if your radio has expo, set some of that into it too......I think with reduced throws and some experienced help, you'll be fine.
Mike |
Consider a "Stick" come in several sizes and makers. |
kennydee, I can't think of anything else specific in the setup of the Lazy Tiger....it's very well built and only takes about 6 hours to complete.....the instructions are very good......if you've never used CA hinges before, take your time and follow the instructions, they explain it very well.......I painted the lines on the inside of my canopy to make it look nicer....I can't really think of anything else......oh, careful with the tail feathers.....they glue on top of the rear of the fuselage....make sure they are square (mount the wing and check it before epoxying) I had to sand down one side of the fuselage where the horizontal stab mounts to get it right.
Mike |
