CG Ultimate 10-300
Just got this and it has flimsy wire gear, what kind of gear should I get and whre? I've seen pics of it with regular gear and not wire, if so, how do you mount the gear in the plane? thanks
CG Ultimate 10-300
1 Attachment(s)
On mine (the kit....not the ARF), I just bought a piece of cheap 1/8" x 2" aluminum from the home center and made one. It works fine unless you really smack it down. But I guess that goes for any of them. You can get 6061-T6 aluminum from McMaster Carr (or a variety of other places) which will be stiffer than the home center variety. I just replaced the grooved landing gear block with a piece of 1/4" ply. I think that I made it a little wider than the original and attached the gear with blind nuts and screws.
