setting up pull-pull on a rudder
I have a 60 sized seagull edge 540 i'm going to setup as a pull-pull rudder. can i just use standard control horns bolted back to back on each side of the rudder and a standard servo arm? I haven't ever attempted to set one of these up.
Derek |
RE: setting up pull-pull on a rudder
I just did the same thing and it worked great,, there is a little slack at full throw but nothing to worry about
No problem, I buy the longer servo arms though so I have more adjustment option.
Two things to to know
1 The horns need to be installed so that the holes line up with the hinge line on the rudder. 2 The distance between the holes that you use on the HORNS needs to be the same as the distance on the SERVO ARM holes. Most people use an extra long servo arm to help with this. Lots of stuff on the web on this subject but the above points are the key to getting it working right. |
In a thread right above yours is a thread with this link. It explains the pull-pull geometry. http://www.qmfc.org/school/ackerman.htm
Like mentioned above, check out the Ackerman bit, it is very important to NOT have any negative Ackerman in your setup, some positive (where the line goes slightly slack on the non-pulling side as you go off neutral). And, the length of the horns and the length of the servo arms DO NOT have to be the same length. As long as you do not get any binding at the extreme ends of the throw, you can safely have quite a bit of difference. I use pull-pull on both rudder and elevators on most of my planes and always have different lengths due to whatever is required to get the desired amount of throw. Check out Alan's web site for some good info on using pull-pull. http://homepages.ihug.co.nz/~atong/
The slack is from the mounting point of the wires. If the holes used in the rudder horns are 2" apart for example, then use the holes 2" apart on the horn. Make sure you figure the thickness of the rudder into your measurement so you have the total distance between the holes. That being said a lot of guys have slack in their cables at full deflection. Most of the time it's not a big deal.
David |
The thread link posted by airbusdrvr has some excellent info. I will use the article's advise and mount the rudder horns slightly behind the hinge line to ensure that the "back side" horn / wire will have slack when tension is applied to the "front side" horn. If turning right, the right rudder horn is the "front side" horn and the left is the "back side".
Slack should be avoided if at all possible even at maximum deflection because of the possibility of control surface flutter.
I agree that with small surfaces and slow speeds then flutter is unlikely but if you explore the envelope fully esp. in 3D style models then flutter might just bite one day. My OMP YAK with a 120 AX would do climbing spins on full throttle both upright and inverted but I had to fix the slack in the elevator linkage to stop the whole tail fluttering. I was able to see it happen and get out of the flutter situation instantly so there was no damage. |
ORIGINAL: j.duncker Slack should be avoided if at all possible even at maximum deflection because of the possibility of control surface flutter. I agree that with small surfaces and slow speeds then flutter is unlikely but if you explore the envelope fully esp. in 3D style models then flutter might just bite one day. My OMP YAK with a 120 AX would do climbing spins on full throttle both upright and inverted but I had to fix the slack in the elevator linkage to stop the whole tail fluttering. I was able to see it happen and get out of the flutter situation instantly so there was no damage. |
ORIGINAL: Rodney ORIGINAL: j.duncker Slack should be avoided if at all possible even at maximum deflection because of the possibility of control surface flutter. I agree that with small surfaces and slow speeds then flutter is unlikely but if you explore the envelope fully esp. in 3D style models then flutter might just bite one day. My OMP YAK with a 120 AX would do climbing spins on full throttle both upright and inverted but I had to fix the slack in the elevator linkage to stop the whole tail fluttering. I was able to see it happen and get out of the flutter situation instantly so there was no damage. |
What rodney is saying makes sense.On a silly note think about the poor people flying big scale yaks and the three rudder servos all looped up with stainless wire humming and we're still on the ground after switching on.Thers six strings there and if you pluck 'em hard enough sounds like the theme from deliverance..da da da dum dang dum ding dam dang who?)cheers
Hi!
Rodney is right! Slack in one wire does not induce flutter! What causes flutter is a too flimsy stab ...or elevator surface itself. |
I suspect that everybody here is sort of right about flutter. If you have a sufficiently sturdy control surface, you shouldn't get flutter, even though you have some slack in the one wire. If your control surface has some give in it, having no slack, if you can get there, might help keep that surface from flexing, and so reduce the chance of flutter. This is more a gut reaction than an analysis. Seems possible, though.
