OS91pumped fs
My exhaust fell off during flight today I flew for at least 15min before I realized it was missing. My question is did I harm my engine in any way? This is my first four stroke so a bit of help would be great. Thanks in advance.
RE: OS91pumped fs
Anyone[&o]
RE: OS91pumped fs
I've got an OS 91 F/S that I've run many times with just the header pipe and no muffler. There is a guy at my club who has been running a Saito F/S without a muffler or pipe for years. (His threads are broken out of the head.) It seems to have had no bad effect on his engine, so I don't think that you've hurt your engine.
Cheers! |
RE: OS91pumped fs
Nope, no problem. I have run my 1.20 for several years with just a header and one of my non pumped .91s seems to keep breaking the header off right at the head. As soon as the pipe or muffler comes off the non pumped engines you know about it instantly though, they like there muffler pressure.
RE: OS91pumped fs
Thats great news. From a technical point does a pumped engine need a exhaust to operate ? Could you just extend the header pipe etc. I come from a heli background and as you know exhausts are critical for performance. Thanks.
RE: OS91pumped fs
A pumped engine doesn't need to be pressurized from the exhaust because the fuel is delivered by the pump. You can run it with just the header pipe as long as the noise isn't a problem.
Cheers! |
RE: OS91pumped fs
Thanks for the advice. I dont have a noise problem at all so ill fly on the header pipe only. Thanks again.
RE: OS91pumped fs
ORIGINAL: shiver Thanks for the advice. I dont have a noise problem at all so ill fly on the header pipe only. Thanks again. |
RE: OS91pumped fs
Had a couple of flights yesterday. No problems Thanks guys.:)
