ASP 46 same as MAGNUM 46?
I have an ASP 46 with a bent crankshaft. Is the ASP the same as MAGNUM?
RE: ASP 46 same as MAGNUM 46?
Yes...made in the same factory...just different badging / packaging.
Thank you very much for your assistance. I will contact the supplier and see about getting a new crankshaft.
You're welcome...
You should be able to get a crank from Hobby People... (is that the dist. you are talking about? ) |
