RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   CA Hinges vs Nylon Hinges (https://www.rcuniverse.com/forum/questions-answers-154/9957474-ca-hinges-vs-nylon-hinges.html)
tmenold 08-24-2010 06:25 PM
I recently had a little bit of a hard landing with my 90 size Funtana and popped the CA hinges out of the rudder. I'm a bit concerned to repair it with new CA hinges because the existing area that the old CA hinges were is already soaked and hardened with old CA. I was planning on expoxying in nylon hinges for the repair job. Does anyone have any thoughts on the do's and don'ts of a job like this? I've only used nylon hinges one other time and got along OK with it (slicing the slot a little bigger, scratched up the hinge a little more before insertion for a better bite with the epoxy, smeared vaseline in the hinge part so as not to get any epoxy in it, etc.). Thanks for any advice!
j.duncker 08-24-2010 08:13 PM
RE: CA Hinges vs Nylon Hinges
See other thread nearby on pinning hinges.
BTW I rest my case.
tmenold 08-24-2010 08:44 PM
Thanks j.dunker, I read that after I posted this. Good info!
