Engine Recommendation for Yak 73"
#51
IA
RE: Engine Recommendation for Yak 73"
While you are at www.centralhobbies.com check out the Hyde soft mounts. It will be a necessity if you plan to install the 1.60 on the Yak.
Chad
Chad
#54
MN
ORIGINAL: MOTORMAN37
How many are solid mounting YS 1.40 Sport. I am building the Aeroworks .90-1.20 Yak and wondering if a Hyde mount is needed with the YS 1.40.
If you use Aluminum mounts (always better because they do not resonate any High frequency waves like a plastic reinforced one does),
you should be just fine..
I wonder if anyone has tried to make a rail syle mount made out of CF?
#55
IA
I had a YS 1.40 sport hard mounted on mine.... It worked 'fine'. If you are particular about minimizing vibration to save on current draw due to vibration, the hyde mount is a very good investment.
KockJ, is that the new ZDZ 40? I would think that engine would be a perfect match for this plane.
Chad
Chad
#56
MN
ORIGINAL: arobatx
Chad
Chad
Yes it is!
I will be placing it in a QQ yak GEN II this winter.
Look for a build within the coming months!
Justin K.
#57
Hi there,
I am planning to start the 73" Yak as my next project and have an OS 120 AX ready to go - I will be flying IMAC with this plane and I fly at sea level. Thought the 120AX would keep the weight down nicely.
Thank you in advanced.
