Engine Recommendation for Yak 73"
Old 10-06-2006, 11:01 AM
ken graham
My Feedback: (10)
Default Engine Recommendation for Yak 73"
I'm just wondering what engine I should put on that plane? I don't have the plane yet but next time I get thru springfield I'm going to pick one up. I have a saito 180 and a mark 2.1 on hand but I think the 2.1 will be waaaay over kill. looking at the os 1.6 fx but alot of people say they have some sort of problem aka: fuel draw/air leaks, not enough pressure to draw the fuel, has anyone thought about using the stock os muffler? instead of a pitts style muffler. also looking at the dave patrick 1.8 with a pitts muffler. I do not really want to go gas it just up's the wing loading alot. looking to stay as lite as possable. will the saito 180 give it unlimited vertical with just running 15% nitro? I'm looking for great performance (3d). I know that I opened a can of beans here but anyones help would be great. the field elevation is only 850 ft msl at the local airport would like to use one type of fuel for all my glow airplane getting tired of hauling 0%-15% and gas to the field all the time. I've been on the os support sight and bax says to run large fuel line on the os 1.6, also he reccomends using the stock muffler over the pitts style, can i go with that setup? would that require carving up the firewall and the cowling? I have all winter to decide so I have a little time to think about this. any responce will be great,thanks.
ken graham is offline
Old 10-06-2006, 11:04 AM
Rezagh
My Feedback: (73)
Default RE: 73" yak which motor??????
Hi Ken,
I think your Saito will be good enough at your elevation. You should be able to pull it around with authority. OS also works great. It's really your call.
Reza
Rezagh is offline
Old 10-06-2006, 11:12 AM
arobatx
I run the YS 1.40 sport on mine, cool power heli 30 fuel, APC 18x6 prop at 9100 rpm, 3D is aggressive, no disappointments on performance in any way. I've played with the Saito 1.8, and on the same fuel they run well. they really like the 30% heli fuel. If you like to tinker, I have a converted G26, machined down so there is NO excess material on the case, electronic ignition, with muffler, and it weighs 40oz RTF, which is only a little more than the 1.40. I can run 14 mins on 10oz of fuel, so I am carrying almost half the fuel weight compared to the 1.40 as well. this engine spins the Mezjlik 18x6 at 9000 just like the 1.40 does. The Yak weighs 11 lbs even with the 1.40 and all metal geared servos and a large NiCd battery...with the modified G26, small ignition battery and small receiver battery, it weighs 11 lbs 2oz. There is no performance difference, both are great, the four stroke sounds better, the gas is a lot cheaper. Good luck!
arobatx is offline
Old 10-06-2006, 05:20 PM
randy racer
ken, i have had the 72" with a 160fx with a pitts style muffler and a perry pump and it ran great(still does). on my 73 i have had a 3W 28cc and the YS 140 sport, both fly the plane very well but the 3w has more power and burns cheaper fuel. i am selling both engines and going back with the os 160 and a mouse can pipe. if any one wants a 3W 28 i'm selling mine for 500.00 with pitts mufler, stand offs, 5 props,and spinner. the YS is going for 325.00 with a prop and alum prop nut. both engines are almost new and in great shape.
randy racer
randy racer is offline
Old 10-06-2006, 09:42 PM
ttski
I am running the OS160 with Slimline Pitts and Perry pump. The pump is key because of the distance of the tank from the carb. I tried the Bison Pitts. I switched to the Slimline and picked up over 400 rpm and lost a few ounces of weight. A friend here at the field is flying the 72 inch with an Evolution 26 CC. He says the power is much better on mine with the OS160. If you are going to run a small gasser you have to have it on a tuned can or pipe to get the performance.
ttski is offline
Old 10-07-2006, 01:35 PM
Zippi
My Feedback: (10)
Zippi's Avatar
ken graham,
I have the YAK 54 73" with a Brillelli 40cc on the business end. I haven't flown it yet but have seen some video of the same plane and engine combo and the power is awesome. Unlimited vertical running a XOAR 20X8 prop.
Zippi is offline
Old 10-07-2006, 09:43 PM
ken graham
My Feedback: (10)
has anyone thought of running a small header tank next to the firewall like they do on heli's?? leaning towards the 1.6 fx.
Old 10-07-2006, 11:05 PM
randy racer
you need the fuel tank on the c of g and you will have a hard time getting fuel to pump up to the engine even with a header tank. the perry pump is the way to go, it's easy and trouble free. i have set up two planes this way with no problems. i also used a fuel magnet in the tanks so it never gets any air bubbles.
randy racer
Old 10-09-2006, 08:33 AM
johnboyrc
If your in Menomonie, you shouldn't have to worry about elevation. I have an os on my yak, but only have a few flights on it. I don't have a perry pump on it, but I'm not looking to do a lot of 3D yet. If I was, the perry pump would be the way to go. A friend had that setup on his Giles, works pretty slick.
I didn't want the engine inverted, so I have it sideways with a slimline pitts muffler.
johnboyrc is offline
Old 10-12-2006, 09:19 PM
shesha
Saito 180 with 18x6w APC prop ballistic verticals, if your after 3D.
shesha is offline
Old 10-30-2006, 01:34 PM
EMVIN
Default RE: Engine Recommendation for Yak 73"
I am currently flying the QQ 73" with a Saito 180 using a perry pump, prozinger 18X6 and Morgan Cool Power 30% Heli Fuel.
At approximatly 8500 rpm performance is amazing. unlimited verticle, hovers at 1/3 +/- throttle. This is a great combo. The plane weighs in at 11lb 11oz..
EMVIN is offline
Old 12-03-2006, 09:05 PM
grundo one
Hi Guys.
I need to know which perry pump i need to use for my saito engine. Should i use the VP 20 oscillating pump?..or the VP 30?
Bob.
grundo one is offline
Old 12-04-2006, 08:54 AM
EMVIN
VP-30.......click on this link it shows set up and other info http://saito-engines.info/pumps.html ....EMVIN....
EMVIN is offline
Old 12-04-2006, 10:03 PM
xxsnookxx
brilleli 40cc here 7 0z. more than os 1.60 sick power no slime...
xxsnookxx is offline
Old 12-05-2006, 10:23 AM
ken graham
My Feedback: (10)
well i went for the ys 140 sport, hope to get it in the air before it's to cold up here. the plane is really light for it's size. I'm going to try a APC 18-6w prop first and see how things work.
Old 12-05-2006, 10:57 AM
wavy777
Hi,
Just to confuse things I have a 72" GSP giles which is about 11.5 lbs dry, similar to the Yak. I have a Moki 1.35 turning an APC 18 x 6w, Bisson Pitts silencer and straight fuel. Vertical performance is unlimited....
Cheers
W
wavy777 is offline
Old 12-06-2006, 09:56 AM
merlin3
ken I had better luck with the zinger 18x6 over the apc on my ys so that might be something you can try as well.
merlin3 is offline
Old 12-06-2006, 04:57 PM
adrenalnjunky
My Feedback: (18)
removed - completely different thread than what I thought I was posting in.
adrenalnjunky is offline
Old 12-06-2006, 05:08 PM
arobatx
The Zinger pro flexes a lot and the APC is heavy, try a Mezjlik 18x6, you'll love it.
arobatx is offline
Old 12-06-2006, 05:19 PM
ctnic
I am running the YS140 Sport with the Bolly 19x6 carbon fiber prop and 30% heli fuel. This is my first plane of this caliber and capabilities and loving every minute of it.
ctnic is offline
Old 12-06-2006, 05:23 PM
arobatx
Cool, never tried a 19x6 carbon....what RPMS are you getting with that combo at your elevation in MI?
arobatx is offline
Old 12-06-2006, 09:41 PM
ctnic
I am running the engine between 8900-9000rpm (The most I have measured when tunning the high end before it started falling back off is 9300rpm) in temperatures ranging from 32-55 degrees fahrenheit.
ctnic is offline
Old 12-07-2006, 09:33 AM
arobatx
All I needed to hear, I have one of those props on the way. Thanks!
arobatx is offline
Old 12-12-2006, 12:34 AM
sergio varo
Hi, Iam thinking about buying a yak 54 73 and putting a YS 140 sport.Dont know what type of header and muffler to use and if hitec digital 5645 servos would be okay.Thanks serg...
sergio varo is offline
Old 12-12-2006, 02:30 AM
chuck4816s
I am running a hacker c50 14 xl with a 22X12 mejlik carbon prop.My batteries are 10s2p duralight evo 20s. * min flights doing hard 3d work. Verticals are breath taking. I am located in ohio I f anyone is looking to buy a used airframe at a decent price. Looking to move in to a 40 % plane for imac next year
chuck
chuck4816s is offline
