Radio System for 102"
My Feedback: (50)
I'm putting my 102" Yak together and need some advice on how best to set up radio system. I'm using a JR 10X with 8 8611A servos.
I'm trying to decide if I should go with two receivers and batteries or just one. Would there be any power issues with just one receiver?
Also, how are the JR 2000 receivers performing? I have a couple of the JR945 receivers I could use but would buy the 2000 if they are more reliable.
What size batteries (NiMh) are most folks using on this plane for a one or two receiver setup?
Dave Burton
Dave Burton
My Feedback: (73)
RE: Radio System for 102"
Hello Dave,
One receiver would be just fine. Quique and I both are running R2000. Running two batteries would be your decision. I have two planes, one I am running one receiver and one battery, the other is a redundant system with Duralite SC-12 powerbox.
As far as batteries go I rather use Li-Ion than NIMH.
Check out some videos of my plane at www.rcmodelaviator.com the plane I am flying is running one R2000, one Duralite 4300 and one receiver. Can you say I am lacking any current to the servos
Thank you,
Reza
Thank you,
Reza
NC
Dave , give me a call and I will send pictures of my set-up . I am using one battery and one reciever. I have flown this set -up since last year with no problems. Hope this one doesn't run away from home like the last yak !!! TERRY
CO
i was thinking of getting the 102" yak and i was wandering if my hitec 6 channel computer radio would work or would i have to get a better radio?
Dave, if you choose nimh's, go with something like dual 1400mah 5 cell packs for the receiver with dual HD switches and a 4-cell for the ignition and you will be fine. It will be good for 4-5 flights easy. I don't run the nimh's in my big stuff, but I have that exact setup in a 50cc plane that works fine.
My Feedback: (73)
One for Aileron if you use one JR matchbox. 2 Elevator, one rudder, one throttle so 5 channel.
Or you can use a matchbox on your elevator and end up wih 4 channel.
Thank you,
Reza
Thank you,
Reza
ORIGINAL: 3W flyer
what if i use hitec servos and a hitec programmer?
For those without 10 channel receivers, a power expander is a great option. It will allow you to use MUCH less channels, while still ensuring the servos are properly powered.
