86" Fuel Tank Mounting Position??
My Feedback: (66)
NY
Has anyone mounted their fuel tank on the CG on the 86"?? Is it possible to do? I know on the 85" it was pretty common to mount it on the CG with a liitle wood trimming.
Larry
Larry
RE: 86" Fuel Tank Mounting Position??
I am going to move mine back to CG position. I'm thinking of moving it back, so that the rear of the tank overhangs the spar tube by about 1". Currently, I am pushed back against spar tube.
Let me know what you come up with.
Aero104
Aero104
My Feedback: (73)
Hi Larry,
I would leave where it is. Quique and I both have flown it and we don't see a need that you move it a little further back. You should be fine as is.
Regards,
Reza
Regards,
Reza
