Python control horn
My Feedback: (17)
KY
Python control horn
100cc python
Reaza in the manual the control horns for the ail are listed as 35mm from hinge line and the servo arms are not listed but there is a pic that make you think its the 1.5 inch arm from jr at the outer hole. My problem is that 35mm is just slightly more than 1.25" and this would give a bad ratio with a 1.5" servo arm. Are the servo arms on the ail meant to be 1.25" with the 35mm control horn height?
My Feedback: (73)
RE: Python control horn
Let me check mine but I guess I am pretty sure it is 1.5" arm. As for the ratio, I don't think you should be that concern on the ailerons where it's meant for 3D throws! Elevator and precision does make a little resolution difference but aileron I don't think its bad at all. At least I never had a problem with mine.
