Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic > Quiques Aircraft Support - CLOSED
Reload this Page >
86" Yak Different angle of attack on stab halfes
Old 03-15-2009, 08:25 AM
ulfsve
Default 86" Yak Different angle of attack on stab halfes
Hi,
When finalizing radio mount and servo setup i discovered angle of attack differs between stab halves.
I measured and found right to be +0,5 degrees and left to be -2,0degrees!!!
This clearly disapointing, exact alignment should be part of a quality kit.
I have to correct this and I wonder what is the correct angle of attack?
Should it be 0 degrees or is +0.5 ok?
Could someone answer fast on this?
Ulf S
ulfsve is offline
Old 03-15-2009, 10:09 PM
Rezagh
My Feedback: (73)
Default RE: 86" Yak Different angle of attack on stab halfes
Ulf,
Sorry about that. It is +0.5 degree!
You can correct this by playing with the anti rotation pin location.
Reza
Rezagh is offline
Old 03-16-2009, 01:22 AM
ulfsve
Thanks for this fast reply Reza!
I assume this means that wing shall have +0.5?
/Ulf
ulfsve is offline
