86" Yak Different angle of attack on stab halfes
Hi,
When finalizing radio mount and servo setup i discovered angle of attack differs between stab halves.
I measured and found right to be +0,5 degrees and left to be -2,0degrees!!!
This clearly disapointing, exact alignment should be part of a quality kit.
I have to correct this and I wonder what is the correct angle of attack?
Should it be 0 degrees or is +0.5 ok?
Could someone answer fast on this?
Ulf S
Ulf S
My Feedback: (73)
RE: 86" Yak Different angle of attack on stab halfes
Ulf,
Sorry about that. It is +0.5 degree!
You can correct this by playing with the anti rotation pin location.
Reza
Reza
