R/C Sky Diving Discuss all aspects of r/c sky diving and divers here!
My hand made parachute
Reply
Old 09-27-2011, 04:07 AM
padobranac88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My hand made parachute
Hy to all! I want show my project. I spent a lot off time to make this. You can see pictures and write suggestions. Parachute is 90% finished but i need make skydiver... I need help in tihis. Can you tell me where I can see plan for handmade skydiver?
Parachute dimensions: 140cm x 70cm
p.s. teddy bear is only forphotography
ID:	1666860   Click image for larger version
ID:	1666861   Click image for larger version
ID:	1666862   Click image for larger version
padobranac88 is offline
Old 10-14-2011, 08:43 PM
GaryV
GaryV's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: My hand made parachute
Hi,
Glad you found our gathering place. Hope the chute building is going well, it looks good.
I will attempt to up load a picture of the plans that I built my first skydiver from, for some reason my uploads haven't been working very well.
The skydiver with the camoflauge suit is the one made from the plans. (they are Wally Gitchels plans)
mine only came out weighing around a pound and a half, which will be too light for the size of your chute.
You can use the picture to get a basic design of what you need for the body to get the servos situated and have room for the receiver and battery pack.
Be sure to use high torque metal gear servos.
Instead of using the music wire for the arms and legs, I would suggest using plywood or some type of nylon if it is available to get the weight up.
But remember, you can always add lead for weight later if you need it, but it is hard to make it weigh less after it is built.
The pics of the one with the aluminum body has arms and legs made from industrial nylon.
It is very tough but it weighs too much for any of the chutes that I currently have.
Hope this is of some help to you, and good luck,
GaryV
ID:	1674473   Click image for larger version
ID:	1674474   Click image for larger version
ID:	1674475   Click image for larger version
ID:	1674476   Click image for larger version
GaryV is offline
Contact Us Archive Advertising Cookie Policy
