R/C Sky Diving Discuss all aspects of r/c sky diving and divers here!
Release Pin
Reply
Old 05-22-2008, 10:39 PM
Ucak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Release Pin
Thanks to the help of many I have the flag attachment figured out. I would like to see some pictures on how you are releasing your pin from the pack. It seems that some are using a switch that will work twice when they are releasing the flag... once for the chute and then once for the flag. I have a Futaba 6axs could I modify it for such a switch? I gues I need one servo that will release both packs at different times.
Any pictures on your chute release system would be great.
Brad
Ucak is offline
Old 05-30-2008, 06:56 PM
R/C Skydiver
R/C Skydiver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Release Pin
Brad. Can't help you on the Fu transmitterI'm a JR man! Most of us use a dedicated servo
on a two position switch to release the chute then release the flag after the chute has deployed.
If you have a two position switch that can be programmed, you got it made. I first tried opening the chute and dropping the flag with the same one position switch-that didn't work too good although I did get a FEW clean openings, the % is pretty low. Too many
times the flag tangles with the chute causing a streamer-not good! Good luck! Jim
R/C Skydiver is offline
Old 05-30-2008, 07:35 PM
tstotts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brad us channel 5 and use the retract switch if you don't have retracts.
tstotts is offline
Old 05-30-2008, 07:37 PM
tstotts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ooops you need 2 releases. I didn't read close enough. sorry.
tstotts is offline
Contact Us Archive Advertising Cookie Policy
