jammin x1cr drive sharfts
hello im tring to find out if the x1 and x2 buggys run the same drive sharfts front centre and rear im fixing my old x1 and need drive sharfts thank also does the x2 come standard with 16mm big bore shocks .or just 13mm thanks .
RE: jammin x1cr drive sharfts
Visit www.ofna.com
They offer online manuals that show all the part number,compare the shaft numbers
With that said I used hyper7 sport driveshafts in my x1cr lastnight,different numbers but perfect fit,most shafts are the same just made from different material
lets make sure,measure your shafts and i'll measure my hyper 7 pbs shafts and mu X1CR's,my hyper 7pbs's are aluminum
my X1Cr shafts are steel and I replaced them lastnight with Hyper 7 sport(long disscontinued and replaced by the tq) shafts fit perfectly in my x1cr
also if you go to sites like www.towerhobbies.com they list lenths on shafts and you could compare lenths
alright jammin x1 part numbers rear 40571 and 127mm long. front 40521 and 129mm long. i had a look on tower and the x2 front was the same part number but no longer available so im thinking there the same .let me no what the hyper lenth is .thanks ian
my hyper7 pbs is diffrent 104/93 mm
heres some cheap x1crs http://www.nitrohouse.com/catalog/pr...ducts_id=12222
I know my old buggy was a tq sport and im running tq sport shafts in my x1cr
at $16 id buy from nitrohouse,They get directly from ofna and its the first place ofna recommends
also chek out the ofna forum,its slow but theres lots of info there
http://ofna.com/forum/index.php?sid=...060a8d2960edee
the X1 and X2 use the same front and rear drive shafts but the center ones are way different. i tried to make my X1 centers work on my X2 bc the X2 ones wear fast but they were way off. if you have an X1 do NOT convert to an X2, the X1 is WAY better with 16mm shocks. the shock shafts between the 16mm and 13mm are the same by the way.
thanks four the info redlined and jmaxy i was thinking they were the same front and rear four the x1 &x2 but just wanted to check. so i will have to buy x1 centre axels and can you's x2 front and rear .i will get some 16mm shocks aswell thanks again four the info .
ORIGINAL: ian urquhart
NH
for those interested. on the x2 buggy. the odonnell sg center shafts actually fit / last better than the ofna ones, and are 75% cheaper. ($11 compared to $45)
also hong nor produces steel center universals for the x2 which you cant order or buy direct through the usa. i occasionally see them on ebay though. (part# x2s-13)
ORIGINAL: worstluck
